How to Help Simplify and Accelerate Identity Recovery
Identity recovery can be complex and highly manual. Learn how automation, orchestration, and unified workflows can help support faster, more trusted restoration.
Key Takeaways
Identity recovery becomes more manageable when teams reduce manual work, coordinate recovery steps, and manage hybrid environments through unified workflows.
- Active Directory (AD) recovery can require 50 to 100 or more prescribed steps.
- Automation and orchestration can help reduce dependence on precise manual execution.
- A unified control plane can help simplify recovery across hybrid identity environments.
- Trusted recovery points help teams restore identity systems with greater confidence.
- More efficient restoration can help minimize downtime and operational risk.
- Centralized workflows can help create a more consistent recovery experience.
Identity recovery is the process of restoring identity systems to a trusted state after an attack, disruption, or unauthorized change. It matters because identity services often control access to the applications, data, and infrastructure an organization relies on every day. When those services are unavailable or compromised, recovery can become a business continuity issue rather than only an IT task.
AD recovery is particularly demanding. The process can require precise execution across 50 to 100 or more prescribed steps. In a high-pressure incident, that level of complexity can increase manual effort, slow restoration, and make coordination harder across security, identity, infrastructure, and continuity teams.
Hybrid environments add another layer because organizations may need to recover identity services across on-premises and cloud-based systems.
A more resilient approach brings automation, orchestration, and centralized recovery workflows together. The goal is not simply to restore data. It is to return identity systems to a trusted state through a process that is repeatable, coordinated, and easier to manage.
By reducing manual dependencies and giving teams a unified recovery experience, organizations can help simplify identity recovery and minimize the operational impact of downtime.
Why Identity Recovery Needs a Coordinated Plan
Identity systems are foundational to digital operations. If an organization’s AD is brought down by an attack or disruption, teams may face a highly manual recovery process that depends on the exact order and execution of 50 to 100 or more prescribed steps. That figure illustrates why an improvised response may create delays and additional operational pressure.
A coordinated plan helps give teams a defined way to assess recovery requirements, identify trusted recovery points, and organize restoration work. It also helps security and identity leaders align with infrastructure and business continuity teams before an incident occurs. The practical objective is to reduce uncertainty when recovery decisions need to be made quickly.
How Automation Can Help Reduce Recovery Complexity
Automation and orchestration can help reduce repetitive manual work and help sequence complex recovery activities. Instead of relying entirely on administrators to execute each prescribed step under pressure, teams can use more consistent workflows to help coordinate recovery and reduce dependence on precise manual execution.
This approach does not remove the need for recovery planning or expert oversight. It helps support those practices by making the process more repeatable. Teams can focus on validating the state of identity systems, confirming priorities, and addressing exceptions rather than spending time coordinating routine actions.
A useful recovery workflow should help teams understand what needs to be restored, coordinate the required steps, and return identity services to a trusted state. Connecting those activities can help organizations reduce operational complexity and improve the consistency of recovery.
How Unified Recovery Helps Support Hybrid Identity
Many organizations manage identity across on-premises and cloud-based environments. Separate recovery tools and processes can create inconsistent workflows, additional handoffs, and limited visibility across the wider identity environment. A unified recovery experience can help teams manage these environments from one control plane.
Centralization matters because incidents do not always stay within one system boundary. Teams may need to understand dependencies, coordinate recovery priorities, and restore identity services in a logical sequence. A single control plane can help provide a more consistent way to manage that work while helping reduce manual effort.
For security and identity leaders, the value is a clearer recovery model. For administrators, it is a more manageable process. For infrastructure and continuity teams, it is better coordination around the systems the business needs to resume trusted operations.
Identity Recovery Best Practices
Start by documenting the identity systems that support critical operations and the dependencies between them. Define recovery roles so security, identity, infrastructure, and continuity teams understand who makes decisions and who performs each part of the process.
Next, help reduce avoidable manual work. Identify recovery activities that can be automated or orchestrated, especially steps that must be performed in a specific order. Use centralized workflows where possible to help give teams a consistent view of recovery across hybrid identity environments.
Finally, make trusted restoration the objective. Recovery is not complete simply because a service is available again. Teams need a process that helps them return identity systems to a trusted state while minimizing the risk of restoring unwanted changes. Review the recovery approach regularly so it continues to reflect the identity environment and business priorities.
The broader lesson is straightforward: Simpler identity recovery comes from preparation, coordinated workflows, and fewer manual dependencies. Together, these practices can help teams recover more efficiently and minimize downtime after an attack or disruption.
Read the full report from ESG to get more information on simplifying Active Directory recovery.
Learn how to simplify and accelerate AD recovery with Commvault Identity Resilience. Join us for the upcoming Identity Recovery Under Pressure webinar at 1 p.m. ET (10 a.m. PT) on Oct. 21, 2026.
Frequently Asked Questions
What is identity recovery?
Identity recovery helps restore identity systems to a trusted state after an attack, disruption, or unauthorized change. It helps support the return of access services that applications, data, and operations depend on.
Why is AD recovery complex?
AD recovery is complex because AD underpins authentication, authorization, DNS, and access across the enterprise. AD recovery can require precise execution across 50 to 100 or more prescribed steps, including restoring domain controllers, replication, trust relationships, policies, and credentials while ensuring attackers or corruption are not reintroduced. Organizations must balance rapid recovery with thorough validation, making AD one of the most challenging recovery scenarios in IT.
How does automation help improve recovery?
Automation and orchestration can help reduce repetitive work and coordinate prescribed recovery steps. This can help make the process more consistent while allowing teams to focus on validation, priorities, and exceptions.
What is hybrid identity recovery?
Hybrid identity recovery addresses identity services across on-premises and cloud-based environments. A unified experience can help teams manage recovery through one control plane and reduce inconsistent workflows.
What makes a recovery trusted?
A trusted recovery returns identity systems to an approved state rather than simply making services available. Teams should validate recovery points and coordinate restoration around known business and security requirements.
What does Commvault Identity Resilience do?
Commvault Identity Resilience provides capabilities designed to help simplify and accelerate identity recovery. It uses automation, orchestration, and a unified recovery experience to help reduce manual effort and minimize downtime.
Explore related resources
